BBD problems
https://slantsix.org/forum/viewtopic.php?t=26186
Author:  cantcatch06 [ Sun Dec 09, 2007 10:23 pm ]
Post subject:  BBD problems
i got a recently rebuilt carter that's confusing me. The car won't idle unless the EGR venturi tap is uncapped. Also when ya remove the vacuum advance it stalls out and dies. I thought it should still run without the advance? Any ideas whats going on with it guys?
Author:  dank10fenny [ Sun Dec 09, 2007 10:51 pm ]
it sucks air at idle on a venturi vac port? where can air be bypassed? and enough to kill it. you have checked timming eh?
Author:  cantcatch06 [ Sun Dec 09, 2007 11:19 pm ]
don;t know if it's sucking air at idle from the venturi port. Only that it won't idle down at all with it capped. timing should be at 2BTDC from where i set the dist less than a week ago.
