Thank you for your patience with my crooked off-topic Qs!
https://slantsix.org/forum/viewtopic.php?t=26194
Author:  Wizard [ Mon Dec 10, 2007 5:31 pm ]
Post subject:  Thank you for your patience with my crooked off-topic Qs!
Got the 32/36 DFEV weber installed on my 1987 2.2 carb caravan with 3 speed auto.
Got everything modified and rearranged the vacuum stuff so everything works including transductor for the spark control computer and used one of hose for vapor recovery, PCV in place, blah blah, modified linkage stolen from one of my 4 junk holley carbs.
Jettings are bang on by recommandation from the carbsonly.com and jet pack, parts as well from there. and All I can say WOW! Weber carb was from ebay (low-miles virgin).
Now I have very fat torque in sweet spot of 2.2L's rpm range and enchanced drivablity. Old non-feedback holley junk even rebuilt 3 times, tweaks to everything etc etc couldn't fix the hammering the tranmission in idle when shifted at standstill, rough idle in gear, engine doesn't pull much at all like basket of OVERCOOKED pasta, and most of all, *pathatic* MPG.
Time will tell on MPG. Keep all updated. :)
Cheers, Wizard
