It is currently Sun Nov 15, 2026 8:49 am
PostPosted: Sun Dec 30, 2007 12:19 pm
I have two options, 3/8" or 5/16" from Napa (Autozone and Kragen show the same options). I crawled under car to measure and I am still not sure. There is a difference in cost of $23 (3/8" being cheaper).
Is there any performance difference or fit difference? It is only a 1/6" difference and there is 5" of rubber hose in between the unit and the hard fuel line, so it should fit on there.
My Swinger gets the Highlight Valet Parking spot over the German sports cars on the Sunset Strip. I love my Mopar.
 Post subject: Stock vs...
PostPosted: Sun Dec 30, 2007 12:32 pm
Stock slant cars got the 5/16" line, the 3/8" was for the performance cars.
If going EFI you might consider the 3/8" version.
The choice is up to you, as your fuel lines under your car will be 5/16".
Good luck,
PostPosted: Sun Dec 30, 2007 1:00 pm
You definitely don't need 3/8". Only the biggest, hairiest, ragged-edge-of-street-driveable big block V8 engines need 3/8". Use the 5/16" and save yourself the hassle of adapting different-size lines.
