| whats the best way 2 .... https://slantsix.org/forum/viewtopic.php?t=26327 |
| Author: | illldeca [ Thu Dec 20, 2007 7:01 pm ] |
| Post subject: | whats the best way 2 .... |
take a broken stud out that holds the manifold on a 225 or do i not need every single one curious.. thanks Dave |
| Author: | slantzilla [ Thu Dec 20, 2007 7:53 pm ] |
If there is any of it above the face of the head you can try welding a nut to it and twisting it out. If not, drill it out and retap the hole. |
| Author: | illldeca [ Thu Dec 20, 2007 8:01 pm ] |
ur right im sure i can weld a nut to it with my miller mig 250 |
| Author: | terrylittlejohn [ Fri Dec 21, 2007 6:29 am ] |
| Post subject: | broken stud |
yes there is a stud tool but you need enough of the shank above the head surface for the teeth on the tool to bite. i like the nut /weld job, the heating and cooling helps break the stud loose |
| Author: | DusterIdiot [ Fri Dec 21, 2007 1:08 pm ] |
| Post subject: | Old trick... |
Quote: i like the nut /weld job, the heating and cooling helps break the stud loose
If the stud is hot enough and you apply a bit of wax around the base it can suck the wax/paraffin into the threads (like soldering copper pipe) and loosen things up (had to do this trick a few times on the rear oil galley plug...)-D.Idiot |
| Author: | Aggressive Ted [ Fri Dec 21, 2007 3:47 pm ] |
I just did that last Saturday. Broke a tap off in the head, at the last exhaust bolt location, even worse than breaking a stud, easy outs are nice but a broken tap? ....... I finally got it out plus a heli-coil that I didn't know was in there. Used Lots of Kriol and was able to work it out with a punch and a ground down and slotted four pronged socket that I made. That stud would never keep leaking no matter what lock-tite compound I used. It is now JB welded in with a new heli-coil. The head is only about 3/8" thick at that location. |
| Author: | illldeca [ Fri Dec 21, 2007 4:34 pm ] |
alright guys im going to put a bigger nut on there and plug weld it horizontal solid wire mig 35mm wire short circuit 18.0 volts 4 wire speed. cuz im good like that illl let you guys know how that goes luckily im becoming a certified welder |
