It is currently Thu May 14, 2026 3:42 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 2 posts ]
 Post subject: radiator swap
PostPosted: Sun Aug 19, 2001 7:38 pm
I am considering an upgrade to later model radiator in my 63 Valiant. The cars I am considering are the F bodies, or possibly a later model A body with slant six (I would assume the V8 models have larger inlets/outlets). My question is, will the upper and lower radiator hoses from the later model car fit into the early A-body after the upgrade? Have any of you folks out there done this before?
Thanks in advance,
Pete Vanderlaan
Virginia Beach, VA
pmvdlaan@picusnet.com
 Post subject: Re: radiator swap
PostPosted: Tue Sep 04, 2001 11:07 pm
: I am considering an upgrade to later model
: radiator in my 63 Valiant. The cars I am
: considering are the F bodies, or possibly a
: later model A body with slant six (I would
: assume the V8 models have larger
: inlets/outlets). My question is, will the
: upper and lower radiator hoses from the
: later model car fit into the early A-body
: after the upgrade? Have any of you folks out
: there done this before?
: Thanks in advance,
: Pete Vanderlaan
: Virginia Beach, VA
Pete,
I have interchanged radiators from my '68 Dart to my '64 Dart and back again. I believe the rad hoses are all the same (trim to length), and the rad mounts are 2-3" wider on the '68 Dart. You can drill 2 new holes in later model rads to match the early A pattern. For early rads in later A's, you need a sheet metal spacer to extend one of the sides/mounts of the rad. Also, my '68 radiator was offset toward the engine, so you may need a shorter fan spacer for the late rad to early car swap. Otherwise, there should be no clearance issues.
Have fun,
madsenl@caltech.edu
