It is currently Tue Jun 02, 2026 6:17 am
PostPosted: Mon Dec 24, 2007 10:55 am
what is the smallest rim size I can run on a 75 valiant disc/10" drum set up? I am swaping the front and rear set up from my 65 valiant to the disc/drum from a 75 valiant. and I need to find some cheap rim to put on until I can find the ones I really want. Will a 14" work? or do I need 15"?
PostPosted: Mon Dec 24, 2007 11:55 am
14" rims were standard equipment on disc-brake A-bodies (early and late). 15"s were not available. The 13" rims will not fit with disc brakes. So the answer is "Yes, go ahead and slap on a cheap set of 14s".
