It is currently Tue Jun 09, 2026 7:27 pm
 Post subject: Rust in carb/time
PostPosted: Wed Dec 26, 2007 9:23 pm
Well, I pulled the lid off my Eddy and there was powdered rust in the bottom of my fuel bowls! :shock: How? I have a brand new 7.3 diesel filter on there, but I reckon rust still gets past it. My fuel tank is probably on borrowed time, but it's not leaking yet. My engine doesn't need that, so what type of filter should I buy that will keep the rust out? Canister? "10-Micron"? Double filters?
Thanks a million!
Footer: I have my slant timing set at "10 before" on the timing tab...is that acceptable?
 Post subject: Fuel Filter
PostPosted: Wed Dec 26, 2007 9:56 pm
BigBlock,
Try a Perma-Cool Fuel Filter and water separator part# 771-81794 at Jeg's or Summit. I used to put one like this on boats all the time. It is a life saver and a good price too! That will keep that nice carb bowl shinny.
PostPosted: Wed Dec 26, 2007 10:04 pm
Rust in the hardline itself, between the filter and the carb?
PostPosted: Thu Dec 27, 2007 6:16 am
Fine enough rust particles can get past filters. I went through this a while back.
You might be able to buy a little time by cleaning out your tank. Replace the sender gasket, filler grommet, and sock while you're at it.
Applying a sealant like THIS should help as well.
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 4 guests
