It is currently Tue Nov 24, 2026 8:51 am
 Post subject: Manifold Help Needed!
PostPosted: Mon Feb 04, 2008 3:06 am
Hi All,
The bolt that holds the intake and exhaust manifolds together (above the heat riser, closest to the engine), would not loosen and has twisted off.
I have my tap and special sized bit ready to drill it out and tap the hole.
Q: How far down into the manifold does the bolt go? Does it open into a pocket, or simply bottom out into cast iron?
Thanks.. I'll be drilling this morning, so quick answers are very much appreciated.
-Mac
PostPosted: Mon Feb 04, 2008 4:43 am
PostPosted: Mon Feb 04, 2008 8:07 am
Thank you. I drilled out the old bolt, tapped the hole and replaced it with a grade-8 bolt.
After much prayer and patience, the manifold is back on with no leaks.
Thanks again.
-Mac
Users browsing this forum: Bing [Bot], Google [Bot] and 2 guests
