| A cheap and accurate way to cc your /6 head! https://slantsix.org/forum/viewtopic.php?t=2644 |
| Author: | Tim_K [ Wed Sep 05, 2001 1:18 pm ] |
| Post subject: | A cheap and accurate way to cc your /6 head! |
Go to <A HREF="http://www.slantsix.com">www.slantsix.com</A> and read it in the tech talk section. I've already typed it twice and don't want to do it 3 times. In short, $15 gets you all you need if you know where to look! |
| Author: | Doctor Dodge (Doug Dutra) [ Wed Sep 05, 2001 9:37 pm ] |
| Post subject: | Re: A cheap and accurate way to cc your /6 head! |
: Go to <A HREF="http://www.slantsix.com">www.slantsix.com</A> and read it in the : tech talk section. I've already typed it : twice and don't want to do it 3 times. In : short, $15 gets you all you need if you know : where to look! Awhh...come-on...you mean your computer does not have that "copy / paste" key...mine does, so heres Tim_K's info: DD I just found a cheap and easy way to cc my /6 combustion chambers. Thought I'd share it with everyone. I found a scientific supply store in the yellow pages, and ordered a 100 ml (same as cc) plastic graduated cylinder, and a squeeze bulb with a tube on it (called a pipette aid). Total cost of $15.20 . 6 days from putting the money order in the mail to FedEx handing me the box, and that's over the Labor Day weekend! The cylinder has a little spout at the top, so you can pour water with it if you want to. The squeeze bulb takes 15 drops of water to move the water level 1 cc (ml) in the cylinder, so accuracy should be very good with it. You'll need to add a short piece of flexible clear tubing to the suqeeze bulb to reach the bottom of the cylinder, which is about 1 inch in diameter and about 10 inches tall. You'll also need your own piece of plexiglass to seal the chamber you're measuring. Price breakdown: Cylinder, $5.25, squeeze bulb, $ 3.95, and $6.00 for S&H. They said that is the minimum price for S&H, and should be sufficient to go anywhere in the USA for that amount. Here's what to do: Call (724) 872-9383, or (412) 751-4415. Ask for Part # 4861-D 100 ml plastic graduated cylinder, and # 5829 pipette aid (squeeze bulb thing). Here's their address: S & S Scientific Supply Co. Inc. 320 Highland Drive Elizabeth, PA, 15037 After one machine shop told me $40 to cc the first chamber and $25 for each one after that, I said NO WAY. A second shop had a better but still too expensive price. With this stuff, you can cc heads until you can't stand it anymore for one low price! |
| Author: | Tim_K [ Thu Sep 06, 2001 1:13 pm ] |
: Awhh...come-on...you mean your computer does : not have that "copy / paste" : key...mine does, so heres Tim_K's info: DD : : I just found a cheap and easy way to cc my /6 : combustion chambers. Thought I'd share it : with everyone. I found a scientific supply : store in the yellow pages, and ordered a 100 : ml (same as cc) plastic graduated cylinder, : and a squeeze bulb with a tube on it (called : a pipette aid). Total cost of $15.20 . 6 : days from putting the money order in the : mail to FedEx handing me the box, and that's : over the Labor Day weekend! The cylinder has : a little spout at the top, so you can pour : water with it if you want to. The squeeze : bulb takes 15 drops of water to move the : water level 1 cc (ml) in the cylinder, so : accuracy should be very good with it. You'll : need to add a short piece of flexible clear : tubing to the suqeeze bulb to reach the : bottom of the cylinder, which is about 1 : inch in diameter and about 10 inches tall. : You'll also need your own piece of : plexiglass to seal the chamber you're : measuring. : Price breakdown: Cylinder, $5.25, squeeze bulb, : $ 3.95, and $6.00 for S&H. They said that is : the minimum price for S&H, and should be : sufficient to go anywhere in the USA for : that amount. : Here's what to do: Call (724) 872-9383, or : (412) 751-4415. Ask for Part # 4861-D 100 ml : plastic graduated cylinder, and # 5829 : pipette aid (squeeze bulb thing). : : Here's their address: S & S Scientific : Supply Co. Inc. : 320 Highland Drive : Elizabeth, PA, 15037 : : After one machine shop told me $40 to cc the : first chamber and $25 for each one after : that, I said NO WAY. A second shop had a : better but still too expensive price. With : this stuff, you can cc heads until you can't : stand it anymore for one low price! This computer has the copy and paste keys, but I never tried to learn how to use them. |
