| Fuel Tank Sending Unit Outlet Size https://slantsix.org/forum/viewtopic.php?t=26445 |
| Author: | LASwinger70 [ Sun Dec 30, 2007 12:19 pm ] |
| Post subject: | Fuel Tank Sending Unit Outlet Size |
I have two options, 3/8" or 5/16" from Napa (Autozone and Kragen show the same options). I crawled under car to measure and I am still not sure. There is a difference in cost of $23 (3/8" being cheaper). Is there any performance difference or fit difference? It is only a 1/6" difference and there is 5" of rubber hose in between the unit and the hard fuel line, so it should fit on there. |
| Author: | DusterIdiot [ Sun Dec 30, 2007 12:32 pm ] |
| Post subject: | Stock vs... |
Stock slant cars got the 5/16" line, the 3/8" was for the performance cars. If going EFI you might consider the 3/8" version. The choice is up to you, as your fuel lines under your car will be 5/16". Good luck, -D.Idiot |
| Author: | SlantSixDan [ Sun Dec 30, 2007 1:00 pm ] |
You definitely don't need 3/8". Only the biggest, hairiest, ragged-edge-of-street-driveable big block V8 engines need 3/8". Use the 5/16" and save yourself the hassle of adapting different-size lines. |
