clutch help
https://slantsix.org/forum/viewtopic.php?t=26476
Author:  ezekiel [ Mon Dec 31, 2007 5:41 pm ]
Post subject:  clutch help
can i replace my 9inch clutch with a 10inch clutch with out changing the fly wheel?
Author:  sandy in BC [ Mon Dec 31, 2007 5:52 pm ]
Nope.....the bellhousing is too small. You are OK with a 9"clutch as long as you make sure everything is working properly.
I have run a 9"clutch between a 5 speed and a quick super6 for a long time.
Make sure you motor and trans mounts are good. Make sure all the linkage is correct and lubricated. Make sure the Z bar mounts are aligned and solid.
Clean everything around the clutch (remove bottom pan) regularly.No oil.
I launch my car at an idle....and then get on it.
Go easy on the downshifts.....learn to drive without touching the clutch.
Save up for a 5 speed.
Author:  ezekiel [ Mon Dec 31, 2007 6:02 pm ]
where is a good place to get a clutch? I am looking at geting one from Autozone..
Author:  Joshie225 [ Mon Dec 31, 2007 6:45 pm ]
Post subject:  Re: clutch help
http://slantsix.org/articles/clutch/sl6-clutches.htm
Author:  DusterIdiot [ Mon Dec 31, 2007 8:55 pm ]
Post subject:  Compare brands...
I recently got a Zoom clutch set, and the disc and pressure plate are fine, but the throwout bearing was made of soft/plastic/ nylon, which fell apart after I hooked it with the clutch fork...so I ended up using a good metal OEM one I had on the shelf...
Author:  Jeffc [ Tue Jan 01, 2008 2:50 pm ]
I would say "it depends" I'm using a 10" in my 73 Scamp
with the stock flywheel.....bolted right up, no mod's,
got it from Napa....
both the 9 and 10 were listed for that year......
the Scamp was a 3 on the tree np250 when clutch was installed,
still in use with the np833od trans and bell.....
Author:  ezekiel [ Tue Jan 01, 2008 3:48 pm ]
The book i got says to use dextron transmision fluid. I was under the impression the dextron was red. the fluid from my transmission looks like gear oil. what weight should I use the 75 or 80?
Author:  Jeffc [ Tue Jan 01, 2008 3:55 pm ]
I like to use synth Mobil 1 Dextron if the seals are in good shape
and you get no "cruch" from the gears when shifting,
75-80 is fine also, 140 is too high unless your in north africa....
