ratios?
https://slantsix.org/forum/viewtopic.php?t=26504
Author:  Bren67Cuda904 [ Thu Jan 03, 2008 12:36 pm ]
Post subject:  ratios?
does anyone know off hand the 1st and 2nd ratios for both the 904 and the low gearset 904?
Author:  Doc [ Thu Jan 03, 2008 1:25 pm ]
904 (standard ratio) 2.45, 1.45 & 1.00 to 1
998 / 999 (wide ratio) 2.74, 1.54 & 1.00 to 1
Author:  wicked/six [ Thu Jan 03, 2008 9:54 pm ]
Is the 2nd to third shift in the 998 set extreamly noticeable, i.e. big difference from the 904?
Author:  slantzilla [ Fri Jan 04, 2008 5:39 am ]
That is the problem with using a low gear set with a Slant. What you gain in low you give back on the 2-3 shift. :(
Author:  Bren67Cuda904 [ Fri Jan 04, 2008 11:45 am ]
I've got a solution for that coming in the mail. :twisted:
