| carter 2bbl jets? https://slantsix.org/forum/viewtopic.php?t=26511 |
| Author: | gato [ Thu Jan 03, 2008 10:54 pm ] |
| Post subject: | carter 2bbl jets? |
i'm just about ready to make my switch to a super six. i've gone thru 2 BBD's. had both throttle shafts rebushed. they are different versions. one has the adjustable metering rods, the other has very skinny meter rods that have no adjustment. the non-adjustable has a plastic hose nipple housing mounted over the accelerator pump. i've never seen that b4. the place where i got the rebuild kits, and the rebush shop, both tell me these were each setup for a 318. my concern is what size jets should i have in which ever 1 i choose to use. i think they have jets marked 120 in them now. for the record, there are no holes in the butterfly plates. anybody know about the jet sizes? D~~~! |
| Author: | Rust collector [ Fri Jan 04, 2008 12:45 am ] |
I am pretty sure my slant bbd has 120 jets too....but it has been a long time since I looked at it |
| Author: | daniel_depetro [ Fri Jan 04, 2008 4:30 am ] |
Good information I'll need in the near future. |
| Author: | Rug_Trucker [ Sun Jan 06, 2008 9:07 am ] |
I haven't seen any with the holes in the butterflies. Probably every carb I have is for a 318 or 273. Two of them might be for a Poly 318. I drilled the jets on one to the next size bit I had. Big mistake! I could have sworn the jets I have say .055. The plastic vent may be a 73 and newer carb. The adjustable rod ones are even newer. I have 2 that have no provision for attaching an air cleaner. No vent tube and look like a little toilet. |
| Author: | SlantSixDan [ Sun Jan 06, 2008 9:45 am ] |
At least the old-style (tall) jets were numbered with a six-digit number. The first three were 120, followed by a dash. So, 120-263, 120-268, 120-575, that kind of thing. Unfortunately, there's no rhyme or reason to the numbers. A 120-263 isn't necessarily one step bigger or smaller, richer or leaner than a 120-264. Holes in the throttle plates started with the Clean Air Package carburetors first released in large number in '66. The plastic vent tube started in '70 (California) '71 (49-state/Federal) and was eventually deleted in favour of completely internal bowl venting. The "solid fuel" BBDs with adjustable step-up rods started around '77. Quote: I have 2 that have no provision for attaching an air cleaner.
'65 and earlier 2bbls used a clamp band ring on the underside of the air cleaner, rather than the '66-up bail-and-wingnut system we're all familiar with 'cause it was introduced in '60 on the 1bbls.'63 and earlier carbs use a choke pulldown piston in a cylinder in the airhorn, rather than the external diaphragm-type choke pulloff. I've posted a large manual on the Carter BBD carburetor here. |
| Author: | DusterIdiot [ Sun Jan 06, 2008 7:35 pm ] |
| Post subject: | Another thing... |
Since I was just out 'fiddling' with one of those 'hole in the plate' 1974-318 BBD's... Supposedly the post 1974 BBD's can use late AFB jets and rods... but I've never found any material to corroborate this or I get the " why are you wanting to rejet a BBD...get rid of it and get an AFB..." -D.Idiot |
| Author: | Rug_Trucker [ Sun Jan 06, 2008 8:13 pm ] |
| Post subject: | Re: Another thing... |
Quote: Since I was just out 'fiddling' with one of those 'hole in the plate' 1974-318 BBD's... Supposedly the post 1974 BBD's can use late AFB jets and rods... but I've never found any material to corroborate this or I get the " why are you wanting to rejet a BBD...get rid of it and get an AFB..."
I can check that as I have a 600Eddiebrock in a bag. A 70 or 71 AVS and 2 small AFB's. Those are disassembled right now. They look the same as the newer stuff IIRC
-D.Idiot |
| Author: | Rug_Trucker [ Wed Jan 09, 2008 7:13 pm ] |
Quote: At least the old-style (tall) jets were numbered with a six-digit number. The first three were 120, followed by a dash. So, 120-263, 120-268, 120-575, that kind of thing. Unfortunately, there's no rhyme or reason to the numbers. A 120-263 isn't necessarily one step bigger or smaller, richer or leaner than a 120-264.
I forgot to check the AFB rods. I was playing with 2 of the oldies last night. One had what looked like the same sized jets as the other. The one I am rebuilding has rods that I checked with the micrometer. About .035" on the fat end, .025" on the thin tip. This one was brass. . The other carb without the place for the wire bale a/c stud the rod was .024" on the big part. And it was magnetic steel! Never saw steel metering rods before. I think the 120 number is on the rods and jets in my Thermoquad "Strip Kit." Weird |
| Author: | 75duster [ Tue Feb 10, 2009 1:52 pm ] |
i have an old carter book that deals mostly with the afb/avs/thermo-quad and it explains carters jet numbering system in it
here. |
| Author: | SlantSixDan [ Tue Feb 10, 2009 4:14 pm ] |
Quote: i have an old carter book that deals mostly with the afb/avs/thermo-quad and it explains carters jet numbering system in it
Oh yes? That sounds like very useful information. Can you scan it in? If so, I can host it.
| Author: | 75duster [ Tue Feb 10, 2009 5:15 pm ] |
i cant scan it but i will copy what it says. its from an old sa-design book "volume two-carburetion:carter carburetors includes thermoquad, afb,avs,and wcfb models." not much about the bbd but it does mention it slightly when it talks about the types of carters. "Carter utilitizes several part-numbering systems for jets, all of which contain information relating to orifice size, but they utilize a unique encoding. All WCFB's, most AFB's and AVS's and 1974 and later BBD carbs use jets with a three digit suffix that describes orifice size. (All Carter jet part numbers begin with "120-") if the suffix begins with a "3" jet size is less than .100-inch; a "4" in the first suffix position indicates an orifice of .100-inch or greater. Thus a .098-inch jet would carry part number 120-398 while a .101-inch jet would be labelled 120-401." it goes into more detail about AVS/AFB three step metering rod jet sizes since they are different, and thermo-quads are in a class by their own. let me know if you want this info, though i doubt any on here are running AVS/AFBs or god forbid and 800 cfm thermoquad |
| Author: | 75duster [ Tue Feb 10, 2009 5:24 pm ] |
this does not apply to carbs before 1974 and my book does not go into much detail about BBD tuning but i do have one of these style carbs back home... but im in wyoming now for school so that doesnt do much good
here. |
| Author: | Rug_Trucker [ Wed Feb 11, 2009 5:29 am ] |
While rebuilding the most recent BBD I took a caliper to the rods. I dropped a drill bit into the jets. The carbs I checked were the "tin top" solid fuel BBD's. One I believe is a '77 318 carb, the others are super six carbs. The jets were the same. The difference is in the rods. One six carb came out of a friends California spec van. I have no idea where the other super six came from. (77 or 78?) I am pretty sure the other is a '78. They have the same rods. My drills could be a bunch better on size selection. I have 2 copies of the old Dave Emanual book in the shop. When I was in the book store a couple of weeks ago I see there is a new edition out that covers the Edelbrocks. I don't remember if it covers the AVS "Thunder Series." |
