It is currently Tue Nov 24, 2026 3:47 pm
 Post subject: clutch help
PostPosted: Mon Dec 31, 2007 5:41 pm
can i replace my 9inch clutch with a 10inch clutch with out changing the fly wheel?
PostPosted: Mon Dec 31, 2007 5:52 pm
Nope.....the bellhousing is too small. You are OK with a 9"clutch as long as you make sure everything is working properly.
I have run a 9"clutch between a 5 speed and a quick super6 for a long time.
Make sure you motor and trans mounts are good. Make sure all the linkage is correct and lubricated. Make sure the Z bar mounts are aligned and solid.
Clean everything around the clutch (remove bottom pan) regularly.No oil.
I launch my car at an idle....and then get on it.
Go easy on the downshifts.....learn to drive without touching the clutch.
Save up for a 5 speed.
PostPosted: Mon Dec 31, 2007 6:02 pm
where is a good place to get a clutch? I am looking at geting one from Autozone..
 Post subject: Re: clutch help
PostPosted: Mon Dec 31, 2007 6:45 pm
http://slantsix.org/articles/clutch/sl6-clutches.htm
 Post subject: Compare brands...
PostPosted: Mon Dec 31, 2007 8:55 pm
I recently got a Zoom clutch set, and the disc and pressure plate are fine, but the throwout bearing was made of soft/plastic/ nylon, which fell apart after I hooked it with the clutch fork...so I ended up using a good metal OEM one I had on the shelf...
PostPosted: Tue Jan 01, 2008 2:50 pm
I would say "it depends" I'm using a 10" in my 73 Scamp
with the stock flywheel.....bolted right up, no mod's,
got it from Napa....
both the 9 and 10 were listed for that year......
the Scamp was a 3 on the tree np250 when clutch was installed,
still in use with the np833od trans and bell.....
http://imageevent.com/jeffc
62 D100 225 3sp lwb
64 D100 A318 727pb custom lwb
66 D100 A318 4sp lwb
68 D100 B383 727 swb
65 Belveder A318 727 4d
65 Dart GT LA273 2bbl 904
73 Scamp 225 2bbl 4spOD
Old iron or no iron
PostPosted: Tue Jan 01, 2008 3:48 pm
The book i got says to use dextron transmision fluid. I was under the impression the dextron was red. the fluid from my transmission looks like gear oil. what weight should I use the 75 or 80?
PostPosted: Tue Jan 01, 2008 3:55 pm
I like to use synth Mobil 1 Dextron if the seals are in good shape
and you get no "cruch" from the gears when shifting,
75-80 is fine also, 140 is too high unless your in north africa....
62 D100 225 3sp lwb
Old iron or no iron
