It is currently Sat Jun 13, 2026 10:53 pm
 Post subject: tach on a slant six
PostPosted: Tue Jan 08, 2008 12:29 am
hey i know there are prolly a ton of post on this but next weekend i would like to but a tack on my 73 dart sl6 225 could someone please give me a old post to look at. so i have an idea if its possable and if i can do it.
thanks!
PostPosted: Tue Jan 08, 2008 12:53 am
???? ESPLAIN It tom e REEEKIE!
What do you want to know about tachs?
PostPosted: Tue Jan 08, 2008 2:52 am
Uhmmm. ok...
Get a tach that can be used with a 6 cylinder, mine has a dial at the back to set it to work with 4, 6, or 8 cylinders.
Wire it up as the instructions say...
Generally, the red wire is switched+12v, black is ground, green goes to the coil negative, and the white is for the light.
What else do you want to know?
Yeah, it works just fine on a slant
PostPosted: Tue Jan 08, 2008 5:56 am
Or you can go high tech and just use an MSD shift light. :lol:
PostPosted: Tue Jan 08, 2008 8:08 am
I have a Sun tachometer on my slant six. I am not very happy with it because it's vary slow respond to the engine revving and it just doesn't seem accurate. I'll spend the money for an Auto Meter tachometer on my other Valiant.
1966 Signet
Turbo Slant Six
PostPosted: Tue Jan 08, 2008 9:07 am
Midi,
I use a Sunpro super tach II..works great. Just three wires as other member told you. I run mine with a Pertronix ignition, but have run it with HEI also. Very sensitive to rpm. I matched it against an excellent hand tach you press against the crank pulley.
Easy job to put in a tach and its internal lite. Just read the directions.
rock
'64d100
Users browsing this forum: Amazon [Bot] and 4 guests
