It is currently Tue Jun 09, 2026 9:13 pm
 Post subject: Bang for the Buck?
PostPosted: Sun Jan 13, 2008 11:25 am
Poser
Milling the cylinder head and /or block sounds like an inexpensive way to bump up the horse power. What kind of return horse power/torque for the money when you put in bigger valves and some mild port work? The build I am planning (some time in the next hundred years) is a slant equipped Ford roadster so it's mainly a street driven car. Thanks for your help with this 'slant - goober.'
PostPosted: Sun Jan 13, 2008 11:58 am
6 Pack Dart
Do both compression is really in the cellar, and the head was designed for a 170 cu inch motor and never changed. so bigger valves and port work really help.
