| Copper Washers on Disk Brake Brake Lines? https://slantsix.org/forum/viewtopic.php?t=26564 |
| Author: | bwhitejr [ Mon Jan 07, 2008 9:25 am ] |
| Post subject: | Copper Washers on Disk Brake Brake Lines? |
Where do the copper washers go on the brake lines to the disk brake caliper? One on either side of the hose connection? Or both on one side? TIA bwhitejr |
| Author: | Dart270 [ Mon Jan 07, 2008 9:43 am ] |
They are gaskets. If you are speaking about the "banjo" hose connection, then they go on both sides. You need 2 for each caliper end connection. FYI, a cheap-a$$ friend of mine tried to make washers out of copper pennies on a lathe and they did not seal - alloy was too hard. Lou |
| Author: | Joshie225 [ Mon Jan 07, 2008 10:22 am ] |
I had quite a collection of brake caliper hose washers since they came with both my rebuilt calipers and the new hoses. Do this with a few cars and one ends up with a lot of washers. |
| Author: | KBB_of_TMC [ Tue Jan 08, 2008 10:59 am ] |
You can buy sets of copper washers from Harbor Freight fairly cheaply. In a pinch I've carefully sanded the old washers very smooth and them reused them w/o problems. |
