| Holley Secondary Springs https://slantsix.org/forum/viewtopic.php?t=26614 |
| Author: | bwhitejr [ Thu Jan 10, 2008 4:12 am ] |
| Post subject: | Holley Secondary Springs |
The literature that comes with the Holley Secondary spring kit has entries for 350 cu in and 402 cu in vehicles. If I scale the information for my 230 cu in Slant six. I get this: RPM to Open RPM at full Open Yellow (Short Spring) 2105 7342 Yellow 2131 7435 Purple 2457 9027 Plain (Std.) 2886 10492 Brown 3472 11288 Black 3482 Never fully opens Do these these numbers bear out in the real world? If so, for a daily driver maybe a Purple or yellow would be better than the "As-Shipped" Plain spring. IIRC D.Idiot uses a Purple spring. bwhitejr |
| Author: | Sam Powell [ Thu Jan 10, 2008 4:37 am ] |
I would go lighter until you get a bog and then back off one size bigger than the one that produced the bog. I played around with Holley carbs on both my slant and my 360. Sam |
| Author: | rock [ Thu Jan 10, 2008 6:27 am ] |
| Post subject: | BWhite, I run purple |
BWhite, I set secondary with black in, then tuned through spring set and found the purple works great for me with a 90 Holley. Of course, t his is on a well "built" slant on an 727 on a truck with a 3.91 and 28 inch tires... But, yellow was also pretty good. rock '64d100 |
| Author: | DusterIdiot [ Thu Jan 10, 2008 7:02 am ] |
| Post subject: | Pretty close... |
I use the purple spring for daily driving in my 390... I back down to the long yellow spring if dialing up for draggin'... and have used only the brown spring when dialing in my 'modified' Holley 600 cfm... If dialing in for a truck, heavier might be better since the load on the engine is a bit greater (load factor)... -d.Idiot |
