4 speed manual?
https://slantsix.org/forum/viewtopic.php?t=26682
Author:  camel21 [ Mon Jan 14, 2008 5:01 pm ]
Post subject:  4 speed manual?
I was just wondering if anyone out there knows where I can get a 4 speed trans for my '72 Demon. It's got a /6 225. I've tried junk yards but I've had no luck so far. Please any info will help a lot!
Author:  SlantSixDan [ Mon Jan 14, 2008 5:51 pm ]
www.car-part.com , searchable used auto parts clear across North America. Put in 1976 Dodge Dart, transmission, search all areas, then on the next screen specify the last option ("M.T. 4-speed"). You'll get a lot of results. Then repeat the search with 1979 Dodge Aspen, and again pick the "4-speed" option on the second screen. You'll get even more results.
Author:  rock [ Tue Jan 15, 2008 1:47 pm ]
Post subject:  I have one and all the stuff if you want it
I have a used, known good one and all the accessories like bell, fork, etc. Used in my '64D100 for bench mockups.
PM me if interested,
rock
'64d100
Author:  SlantSixDan [ Tue Jan 15, 2008 2:09 pm ]
Careful there — car 4spd not the same as truck 4spd in the '60s.
Author:  rock [ Wed Jan 16, 2008 6:34 am ]
Post subject:  Yep, Dan's right, I used car one, is why mockups needed
Yeh,
Good advice to him Dan! Since I am so used to fitting stuff up I forget what I have to do at times to get stuff to work!
I have and finally used A833OD's from cars, with long tailshaft and 23 spline inputs, because I didn't want NP435's with that low low gear. Course doing so required a new crank, thus new engine, modifying one cross from which to take measurements.
If I had known more of what it would take before I got started, MAYBE I would have put in the 727 to start with....naaah, I wanted the 4 speed, then after having it wanted to try something else. Talk about "project creep"! But ya know, us slanters probably all like a challenge.
Still take Dan to heart, I am almost certain you wouldn't want the super heavy truck 4 speed, the NP435. Of course the guys who have done car conversions have posted periodically of the perils they encountered too, so I would caution you that what you want to do is not likely to be plug and play and not be done in one weekend.
rock
'64d100
Author:  daniel_depetro [ Sat Jan 19, 2008 5:22 pm ]
I have an 70k mile original 3-speed from my parts 1972 Demon if you're interested. It can be had CHEAP!
Author:  valiantwagonguy [ Sun Jan 20, 2008 4:59 pm ]
I'd look for a 64-65 Valiant Barracuda Dart iron A833 and use that.It has the 309 first gear and 1to 1 4th and makes for a nice driving 6 .They are out there and so are the bellhousings for them I just bought one last month. It will be a basic bolt in job this way.
Author:  player1up [ Mon Jan 28, 2008 1:25 pm ]
does the crank need to be modified to take the pilot bearing? or is it just a buy parts and swap type thing?
Author:  Charrlie_S [ Mon Jan 28, 2008 1:46 pm ]
The 64-65 trans, has a flange on the rear of the trans, to accept the Ball and Trunion joint. Driveshaft mods would be required.
Author:  volaredon [ Mon Jan 28, 2008 2:17 pm ]
I believe from the other thread that camel wants the non O/D version.
I'd suggest swap meets or Ebay, though I don't know whether his beef is that he only has 3 gears or if its that the shifter is "on the tree".... he's new, maybe if thats the issue (he wasnt real clear ) a tranny hump and a 3 spd shifter and rods would solve his "beef" with his car?
Author:  DusterIdiot [ Mon Jan 28, 2008 7:38 pm ]
Post subject:  If so...
If this is true, then I would heavily suggest the A-230 3 spd (has synchro 1st gear...inland short throw shifter...1971-1974 ish) as the tranny to look up, they are fairly cheap to get, and will bolt right up to his 3spd bellhousing, and then he'll need to install a hump and new carpet.
Good idea!
-D.idiot
Author:  camel21 [ Wed Jan 30, 2008 11:21 pm ]
Hey guys thanks for all the info. But I wanted was a four speed not because the shifter is on the tree but because I want that one more gear and my tranny is leaking really bad right now and I thought to myself well this is the perfect time to get what I want out of her.
Author:  Kidd [ Sun Feb 03, 2008 8:53 am ]
I have a 4speed out od a 65 Barracuda.....withe the ball and trunion tail shaft. It is for sale......and I have a 3 speed from my 67 Barracuda , it had a 273 in front of it. Email me if you want.
Andrew/Kidd
