| 64" Dodge Dart Trany Cables https://slantsix.org/forum/viewtopic.php?t=2671 |
| Author: | Tim Walker [ Wed Sep 12, 2001 3:38 pm ] |
| Post subject: | 64" Dodge Dart Trany Cables |
I am in desperate need of a couple of cables for a 64' Dodge Dart w/ slant six and pushbutton transmission. They are a "Shift Level Cable" (Dodge part # 4-10-01) and a "Speedo Cable"(Dodge part # 21-84-1). Thanks in advance Tim Walker silaswalker@netscape.net |
| Author: | Doc [ Wed Sep 12, 2001 6:02 pm ] |
| Post subject: | Re: 64" Dodge Dart Trany Cables |
: I am in desperate need of a couple of cables : for a 64' Dodge Dart w/ slant six and : pushbutton transmission. They are a : "Shift Level Cable" : (Dodge part # 4-10-01) and a : "Speedo Cable"(Dodge part # 21-84-1). Tim, Are you in need or the "PARK" Lever cable?? The 64 Dart is pushbutton so I'm confused by that discription. There is a "gear selection" cable and a seperate "park lever" cable so let's figure-out which one it is. The speedo cable "core" can be purchased just about anywhere as a "cut to length" kit. If you need the outer housing with the inner cable, those can be found on any 62-66 A-Body. (It may even go back as far as 1960) DD |
