| Holley 2280 https://slantsix.org/forum/viewtopic.php?t=26781 |
| Author: | bwhitejr [ Mon Jan 21, 2008 2:36 pm ] |
| Post subject: | Holley 2280 |
Where can I get a rebuild kit for a Holley 2280? Is it suitable for a Slant Six? TIA bwhitejr |
| Author: | 75plyduster [ Tue Jan 22, 2008 6:00 pm ] |
Im not familiar with it but if you try search it should tell you a little about the carb. |
| Author: | stephaniebrite77 [ Tue Jan 22, 2008 6:20 pm ] |
I'm not sure where you can get a rebuild kit, try all the normal auto parts stores, rockauto.com, other people on here should have some good ideas too. However.. The Holley 2280 is one of the 2bbl carbs that fit on the Super Six intake manifold, which was an option with later /6s (1977-1980). There's an article about the Super Six setup and how to convert here: http://www.slantsix.org/articles/supersix/article.htm. If you're thinking of putting it on your /6, read that article first. It's worthwhile, but unless your engine is already set up for a 2bbl carb, it'll probably be a bit of work. |
| Author: | Rug_Trucker [ Tue Jan 22, 2008 9:44 pm ] |
that was the first 2bbl I ran on my slant. It ran great! |
