It is currently Sat Jun 06, 2026 5:11 am
 Post subject: Holley 2280
PostPosted: Mon Jan 21, 2008 2:36 pm
Where can I get a rebuild kit for a Holley 2280? Is it suitable for a Slant Six?
TIA
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Tue Jan 22, 2008 6:00 pm
Im not familiar with it but if you try search it should tell you a little about the carb.
Ronnie
http://www.cardomain.com/ride/2714941
PostPosted: Tue Jan 22, 2008 6:20 pm
I'm not sure where you can get a rebuild kit, try all the normal auto parts stores, rockauto.com, other people on here should have some good ideas too. However..
The Holley 2280 is one of the 2bbl carbs that fit on the Super Six intake manifold, which was an option with later /6s (1977-1980). There's an article about the Super Six setup and how to convert here: http://www.slantsix.org/articles/supersix/article.htm. If you're thinking of putting it on your /6, read that article first. It's worthwhile, but unless your engine is already set up for a 2bbl carb, it'll probably be a bit of work.
<i>D'Artagnan</i>
<img src="http://img.photobucket.com/albums/v432/stephaniexchaos/dart/th_IMG_0326_zpsumhhfxi0.jpg">
PostPosted: Tue Jan 22, 2008 9:44 pm
that was the first 2bbl I ran on my slant. It ran great!
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 3 guests
