"Open" Open element air cleaner./ Timing
https://slantsix.org/forum/viewtopic.php?t=26803
Author:  Bren67Cuda904 [ Wed Jan 23, 2008 12:38 pm ]
Post subject:  "Open" Open element air cleaner./ Timing
I currently have a 14" x 3" open element air cleaner installed.
http://tinyurl.com/3xj66k (air cleaner)
Could I expect any ET gains from removing the air cleaner all together, or is my cleaner pretty big all ready and not much should be expected?
Ignition timing.
Are most of you guys finding that max power, or should I say, low ET, is with your timing set at pinging backed down a couple of degrees?
Author:  Joshie225 [ Wed Jan 23, 2008 12:47 pm ]
Leave the air cleaner on. Removing it is only going to hurt your piston rings. What can help is an enclosed air cleaner with a sufficiently large duct to feed the engine cool air rather than preheated under hood air.
Lots of testing needs to be done to determine optimum timing. Test, make ONE change and then retest.
Author:  Aggressive Ted [ Wed Jan 23, 2008 2:22 pm ]
Bren,
Run the K&N substack air horn under it. My son is running one and has found it to helps 3 to 4 tenths. Infact he went up from 3" to a 6" K&N for another tenth.
Are you still running the SL6?
If so 30 degrees. Hopefully you have that cam advanced some, like 4 to 6 degrees.
If your pinging did you retard the cam?
Author:  Dart270 [ Wed Jan 23, 2008 4:47 pm ]
On that motor, I would start at 26 deg total mech, and would not go over 30. Air cleaner could help or hurt depending on jetting and element. I remove air cleaner once every 2-3 trips to the track to see if any difference. Never more than 0.1, and usually nothing.
Author:  Aggressive Ted [ Wed Jan 23, 2008 6:20 pm ]
That's were the substack makes a difference, otherwise that's what we found to be true.
