Very Odd performance Upgrade / Idle Enhancement
https://slantsix.org/forum/viewtopic.php?t=26827
Page 1 of 1
Author:  Greg Ondayko [ Thu Jan 24, 2008 2:25 pm ]
Post subject:  Very Odd performance Upgrade / Idle Enhancement
Well On my daily Driver I decided to finally fix the one vacuum motor in the volare that had failed - Like I would be driving for 20 Minutes before the air would come out of the head / Defrost port instead of the Ac Vents.
The reason I waited over 2 years to do this job was because this vacuum motor was mounted inside the Heater box instead of the outside like the others.. So I took it all apart flushed the heater core and installed a new ac evaporator while I was there. Now My defroster / Heater and vents work correctly and I have a way better idle and off idle response too!
Author:  Aggressive Ted [ Thu Jan 24, 2008 2:54 pm ]
Must have been leaking a little vacuum! :D
Good work!
Author:  Greg Ondayko [ Sun Jan 27, 2008 1:17 pm ]
Yeah Ted, I believe it was leaking a whole lotta vacuum. The gas mileage around town almost Doubled from like 12-13 mpg up to 21 Mpg!! around town..
YAY.
