Chrysler-Holley dual injectior TBI - Info Needed
https://slantsix.org/forum/viewtopic.php?t=26835
Author:  tomj55 [ Thu Jan 24, 2008 6:21 pm ]
Post subject:  Chrysler-Holley dual injectior TBI - Info Needed
I plan to convert my 1987 D-150's slant-6 to TBI using a Chrysler-Holley dual-injectorTBI system (TBI. tank and fuel lines) from a 1990 D150 and a MegaSquirt ECU.
I can't find much info about this TBI. My Haynes D150 manual has a few routine maintenance checks, but that's about it. . I picked up the Haynes 1986-1996 EFI Tech Manual, but it doesn't include any info about this model. I contacted Holley, but they couldn't help me either.
It looks similar to a GM Model 200 TBI.
If any of you have any spec or technical info about this model, I would greatly appreciate it.
- TJ
Author:  Rug_Trucker [ Sat Jan 26, 2008 9:28 pm ]
I heard there isn't much in the way of modifications you can do to it. Is this a small block injector, or a 2.2 or 2.5?
I was looking at one the other day on a '90 360 from a van as I was ripping it off to get to the heads.
Author:  sandy in BC [ Sun Jan 27, 2008 7:11 am ]
That Holley TBI setup would be swappable....but....
They are not as good as the GM setup (Rochester 220)
You need to come up with a manifold (I used a Offy with a home made TB adapter)
You need some kind of distributor ....(GM is easy...Lean Burn Dist and HEI Module)
If you have the stuff already go for it....
Author:  tomj55 [ Sun Jan 27, 2008 6:30 pm ]
Rug/Sandy, thanks for the input.
Rug, The TBI is from a 318. I'm hoping that it's sized OK for my 225 slant-6.
I plan to use a Clifford 4-bbl manifold that I have. I just contacted Clifford performance about getting a 4-bbl to 2- bbl adapter. If it doesn't match up, I'll need to fab one myself.
I'm sure I'll need some more of your advice along the way.
-TJ
Author:  Matt Cramer [ Mon Jan 28, 2008 12:45 pm ]
Dan posted some of the injector flow rates in this thread:
http://www.slantsix.org/forum/viewtopic ... hlight=tbi
Author:  tommj55 [ Mon Jan 28, 2008 2:27 pm ]
Great stuff, Matt! Thanks for pointing it out. It saves me from retracing old ground.
