Slant Six Head Gaskets
https://slantsix.org/forum/viewtopic.php?t=26904
Author:  Myron Fountain [ Mon Jan 28, 2008 7:48 pm ]
Post subject:  Slant Six Head Gaskets
I need some help on the various types and thickness of head gaskets for the 225 what is available? Brand and sources also. Thank You!
Author:  Aggressive Ted [ Mon Jan 28, 2008 8:56 pm ]
For head gasket thickness, figure .040 for a Fel-Pro and .045 for all other composite type gaskets.
From the master himself.
Author:  Doctor Dodge [ Mon Jan 28, 2008 10:49 pm ]
... and .020 thick for the factory steel shim head gasket but those are not that easy to find these days.
Author:  1969ronnie [ Wed Jan 30, 2008 7:06 pm ]
d, i just got in 2 .020 shim gaskets, 1947578, 67+older and a 2843182, 68 and newer according to my parts books. other than the 1947578 being a greenish color metal and the pentastar is very detail stamped, they are identical. how much compression can they take? 12-1? will a felpro take more? or less? thanks, ron
Author:  Greg Ondayko [ Thu Jan 31, 2008 2:58 pm ]
I run an estimated 10 - 10.5 on my steel shims no Problems there I use the arp Head studs for added safety.
