1.6 or 1.7 ratio rocker arms
https://slantsix.org/forum/viewtopic.php?t=26905
Page 1 of 2
Author:  Aggressive Ted [ Mon Jan 28, 2008 9:12 pm ]
Post subject:  1.6 or 1.7 ratio rocker arms
Who sells 1.6 or 1.7 ratio rocker arms for the SL6?
Thanks,
Author:  mopardemon71 [ Sat Feb 02, 2008 1:52 pm ]
Right now I am getting people to gether to buy roller rockers from T&D in 1.6 or 1.5 ratio's. I dont think 1.7's are really needed whats your plan for them?
In two and a half weeks and I'm ordering mine. Let me know and we can go in togather and work down the price. This goes for all you reading this post. Lets get this thing started finaily.
Author:  Dart270 [ Sat Feb 02, 2008 3:30 pm ]
I'm in for a set of 1.6s. Let me know how much and when...
Author:  Slant Cecil [ Sat Feb 02, 2008 4:35 pm ]
I'm in for a set.
1.5 is what I want, but if the group buy needs to be the same ratio and the majority wants 1.6, that will also work for me.
Author:  slantzilla [ Sat Feb 02, 2008 9:56 pm ]
I think 1.7's were experimented with when RAS first started building rollers. IIRC, the adjuster screw had to be moved too far in to get the ratio and wouldn't hold up or something like that. :?
Author:  Doctor Dodge [ Sun Feb 03, 2008 9:14 am ]
When you go to 1.7 rocker ratio, the adjuster screw and pushrod move closer to the rocker arm shaft and the pushrods hit on the edge of the head and block.
It takes a good amount of grinding work to get the clearance needed for 1.7 ratio arms.
It is not uncommon to have to do this type of grinding when using the 1.6 ratio but with those, you need less grinding clearance work, if any.
If you use any aftermarket rocker arms, plan to "mock-up" the parts and do not be surprised if you need to do some clearancing and/or geometry correction work.
Author:  Sam Powell [ Sun Feb 03, 2008 12:27 pm ]
In light of Doc's comments, you can take me off the list, if you were thinking of me as a "maybe". . This engine is together now, and I do not want to take it apart at this time, which might be required if I had to grind on the head. Sorry. Good luck on your project though.
Sam
Author:  slantzilla [ Sun Feb 03, 2008 4:20 pm ]
My 1.6 rockers don't get close to the head, but they don't do much else either except look cool with the valve cover off. :?
Author:  Doctor Dodge [ Sun Feb 03, 2008 8:39 pm ]
I have had some engines where the 1.6 set went right on, and then the same set needed some clearancing work on a different engine. :?
In any event, everything needs to be checked so you don't have problems.
Author:  Junior [ Wed Feb 23, 2011 5:39 pm ]
so does anyone make 1.6 rockers now?
Author:  Joshie225 [ Wed Feb 23, 2011 6:39 pm ]
http://slantsix.org/forum/viewtopic.php?p=305579
Author:  DAlexanderW [ Thu Feb 24, 2011 4:07 pm ]
I bought my 1.6 rockers from Clifford Performance.
Author:  Charrlie_S [ Thu Feb 24, 2011 4:25 pm ]
Did you measure them, yourself? Are they actually 1.6 ratio?
Author:  Supercharged SL6 [ Thu Feb 24, 2011 5:55 pm ]
Post subject:  1.6 rockers
I bought a set through clifford 1st set I got where 1.5 they where machined wrong. I had to contact I believe RAS after explaining how I was checking the lift about a dozen times they set up a set on there motor and said your right. They sent me another set in about a week and they are 1.6
Author:  Junior [ Thu Feb 24, 2011 6:49 pm ]
i just looked through cliffords catalog and coulndt find them. do you have to call? how much did they cost? trying to do something of a budget build
Page 1 of 2 All times are UTC-07:00
