| 1971 Dodge 198 choke well gasket https://slantsix.org/forum/viewtopic.php?t=26912 |
| Author: | 79AspenSuperSix [ Tue Jan 29, 2008 6:31 am ] |
| Post subject: | 1971 Dodge 198 choke well gasket |
Where could a guy buy a choke well gasket for a '71 Swinger with a 198 sixer? I tried all the local parts stores with no luck. |
| Author: | SlantSixDan [ Tue Jan 29, 2008 10:56 am ] |
This gasket's been N/A for a lot of years. I keep meaning to have it reproduced but life keeps getting in the way. I'll get at it ASAP. In the meantime, I'm afraid you're stuck with ultra-high-temp copper RTV |
| Author: | Guest [ Tue Jan 29, 2008 11:20 am ] |
You can also get some sheet exhaust gasket, and cut one out. The mounting surfaces need to be in good condition. I've used Mr. Gasket #5961 Ultra Seal Exhaust Gasket Material ... but not for a choke gasket. This would be tough to do, especially since its a thin edge with a hole in the middle... but with enough patience you can do it! EDIT: Also do you need the mechanical choke? Or are you using a manual or electric? This might be useful if you don't need it... I was in the same position you were in, but then I installed a manual choke (electric would work too). Then I took the exhaust gasket material and easily made a gasket to cover the choke port on the exhaust manifold...it was easy since I didn't need to put a hole in the middle. Then I took a 3/8" piece of steel and matched it to the gasket. I then had a little custom block-off piece, no exhaust leaks, and no choke needed! If you are interested in doing this I can get some pics. Hops this helps! |
| Author: | cudaspaz [ Thu Jan 31, 2008 1:54 pm ] |
Yes, pics please. Thanks for posting 79aspensupersix. |
