It is currently Sun Oct 11, 2026 4:31 pm
 Post subject: Need Some Help
PostPosted: Tue Jan 29, 2008 10:49 am
Can someone tell me all the wiring relays and things that are in the engine bay because alot of my stuff was bad or i would like to repalce it
1972 Plymouth Duster 225 Super Six Slant
PostPosted: Tue Jan 29, 2008 10:57 am
Label the units in question with "1, 2, 3,..." then take a photo and post it.
With a image, most of the items can be identified.
Some likely fire mounted units are the voltage regulator, horn relay, ignition ECU and the starter relay.
PostPosted: Tue Jan 29, 2008 1:48 pm
well really what i needed to know iis if thosse needed to be replaced my voltage reg was a little rusty and almost gel on th eback on it and most of the wiring on this car was scraped anyway but most of the relay and reg wherent that much to replace
Users browsing this forum: Bing [Bot], Charrlie_S, DuckDuckGo [Bot] and 23 guests
