| Nominal stall speed of stock converter https://slantsix.org/forum/viewtopic.php?t=27016 |
| Author: | ceej [ Tue Feb 05, 2008 2:23 pm ] |
| Post subject: | Nominal stall speed of stock converter |
What is the average stall of the stock torque converter? I've got a 1974 Plymouth Valiant with an A904 behind the 225. Just trying to get a ball park figure here. CJ |
| Author: | Red [ Tue Feb 05, 2008 5:22 pm ] |
My understanding is that stock stall speed is around 1700 RPM. |
| Author: | ceej [ Tue Feb 05, 2008 8:00 pm ] |
I was thinking it was somewhere around there. Thank You! CJ |
| Author: | Dart270 [ Tue Feb 05, 2008 8:06 pm ] |
Yep, somewhere around 1600-2000. 1800 if I had to pick a number. Lou |
| Author: | slantzilla [ Wed Feb 06, 2008 5:55 am ] |
Quote: Yep, somewhere around 1600-2000. 1800 if I had to pick a number.
They'll go 2400 if ya hit it with a 100 shot. Lou Once. |
| Author: | ceej [ Wed Feb 06, 2008 7:06 pm ] |
Quote: They'll go 2400 if ya hit it with a 100 shot. Once. How 'bout if ya drop a long rod stroker on it? It looks like it's going to be equivalent to perhaps a 70-90 Horse shot. Will the stocker hold up against that? Perhaps I need to go get that 2000 RPM MP converter just for strength? Or were you playing with me? CJ |
| Author: | Bren67Cuda904 [ Wed Feb 06, 2008 7:18 pm ] |
I don't want to jump the gun and recommend someone that I havn't test completely yet, but FTI seems to build a quality converter. Don't know how it performs yet, but I saw it built and it had torington bearsing in it, a special no bulge hub, and a new machined back cover. Not a reused stock one as my midwest is. http://tinyurl.com/2soucb $430 |
| Author: | ceej [ Wed Feb 06, 2008 7:43 pm ] |
$430
Linda flipped when I started ordering brake parts and exhaust for the new build. Shhhhhh! Don't let her see this post! CJ |
| Author: | sandy in BC [ Wed Feb 06, 2008 7:50 pm ] |
Its a race car ...you need a convertor ...not brakes or exhaust! |
| Author: | slantzilla [ Thu Feb 07, 2008 6:04 am ] |
Quote: Its a race car ...you need a convertor ...not brakes or exhaust!
True dat! Someday you guys will learn that a good converter behind a box stock motor will do more good than a hopped up motor with a stock converter. Even a 2bbl motor can use a 3000 stall any day of the week. Stock converters are just that. Stock. |
| Author: | Dan-o [ Sat Feb 09, 2008 9:44 am ] |
So is 412.00 reasonable for a TCI converter for my 18 spline 904? |
| Author: | Bren67Cuda904 [ Sun Feb 10, 2008 5:50 am ] |
That all depends whats in it. You can buy a Jegs converter for $200, but after the guys at FTI cut it open for a customer, you don't want one. |
| Author: | Charrlie_S [ Sun Feb 10, 2008 6:00 am ] |
Quote: Someday you guys will learn that a good converter behind a box stock motor will do more good than a hopped up motor with a stock converter. Even a 2bbl motor can use a 3000 stall any day of the week. Stock converters are just that. Stock. My Z/SA 65 Valint with a 101 hp, 170 slant had a 8 inch convertor and 3.91 gears, with a 22.5 inch tall tire. It could run mid 16's in the 1/4 at 2700 lbs race weight. |
| Author: | Dart270 [ Sun Feb 10, 2008 7:28 am ] |
I'll jump on the wagon here. Converter is well spent money for performance. No substitute if you have an auto. Improvement is 0.5-1.5 seconds in the 1/4 over a stocker. Lou |
