Identify crank
https://slantsix.org/forum/viewtopic.php?t=27055
Page 1 of 1
Author:  Dart74 [ Thu Feb 07, 2008 1:55 pm ]
Post subject:  Identify crank
What 225 engines came with forged crank? Is there a way to identify using serial number on the block or what? This is a 74´ dodge dart 4d.
Thanks
Author:  slantvaliant [ Thu Feb 07, 2008 2:05 pm ]
Cast cranks started about '77, according to THIS
Author:  Doc [ Thu Feb 07, 2008 2:06 pm ]
A 1974 SL6 would be a forged steel crank engine,
The large "casted-in" number on the driver's side of the engine block should be 2806830-xx (the xx can be any number from 1 to 24?)
Author:  SlantSixDan [ Thu Feb 07, 2008 2:25 pm ]
Almost right, but not quite. Midyear '76 was the changeover.
Author:  Wizard [ Thu Feb 07, 2008 3:24 pm ]
Pulled crank tap on them (on the counterweight) lightly with brass hammer:
bell-like ring: forged
CLUNK!: cast.
Cheers, Wizard
Author:  DusterIdiot [ Thu Feb 07, 2008 3:28 pm ]
Post subject:  Scrape the tag...
The pad on the passenger side of the engine above spark plug #1 where the head meets the block will have a set of numbers if '225E' then is cast...
It's kind of weird but of all the '76 A and F bodies of that year I've seen or torn down those with their numbers matching engine all the F-bodies got cast crank engines (except a couple of coupes I came upon with early date codes on the tag)... all the A-bodies seem to have forged crank units (would love to see a 1976 4 door valiant with a cast crank engine as OEM to verify who got 'what')...
-D.idiot
