It is currently Fri May 15, 2026 12:27 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
PostPosted: Tue Sep 25, 2001 8:32 pm
So I'm looking to buy this nice 1963 Dart but the body looks like it has a front clip from another auto and the car has some other modifications. How can I tell that this car is what it is purported to be. Where are the I.D. numbers located one this vintage Dodge so that I can see if they Match with the registration. Thanks in advance for any help.
mhoffperson@msn.com
PostPosted: Tue Sep 25, 2001 10:13 pm
The vin number is inside the drivers side door on the door post, just under the top hinge.
: So I'm looking to buy this nice 1963 Dart but
: the body looks like it has a front clip from
: another auto and the car has some other
: modifications. How can I tell that this car
: is what it is purported to be. Where are the
: I.D. numbers located one this vintage Dodge
: so that I can see if they Match with the
: registration. Thanks in advance for any
: help.
slantsix@netzero.net
PostPosted: Wed Sep 26, 2001 7:47 am
: The vin number is inside the drivers side door
: on the door post, just under the top hinge.
There are also two "hidden vins" on these cars, one is on the radiator yoke, under the "use Mopar Antifreeze" sticker, the other is stamped into the metal of the rear "package tray" under the cardboard. (on wagons, the second one is on the flange, under the rear cargo hatch.
