EGR valve bypass
https://slantsix.org/forum/viewtopic.php?t=27114
Page 1 of 1
Author:  75plyduster [ Sun Feb 10, 2008 5:35 pm ]
Post subject:  EGR valve bypass
When you bypass the egr valve do you just plug the ends the hoses come from and remove the egr?
Author:  Aggressive Ted [ Sun Feb 10, 2008 6:03 pm ]
Post subject:  Egr
Yes, and leave the EGR there, or buy the block off plate and gasket. I paid less than #10.00 for both.
EGR block off plate from the dealer # 3671447 lists for $5 Dealer item, p/n 3671 447, used with standard EGR valve gasket p/n 4173 167.
Author:  SlantSixDan [ Sun Feb 10, 2008 6:07 pm ]
Proceed carefully. Pull the hose off the EGR valve and plug the hose securely, then drive the car around to see if you get a pinging problem, before you more permanently eliminate the EGR.
