| Gas tank resealing https://slantsix.org/forum/viewtopic.php?t=27164 |
| Author: | 75dartcustom [ Wed Feb 13, 2008 11:03 am ] |
| Post subject: | Gas tank resealing |
I got my kit from Eastwood to reseal the gas tank last night. The instructions say to use compressed air at 1-5 psi to keep the sealer from pooling as it dries. I am supposed to seal the sending unit opening, insert the compressed air from the filler opening and keep it from getting too close to any one surface so it doesn't create a thin spot. I have an air compresser I use for trim work around the house and a nozzle to blow air. Will this work? Has anyone ever done this? |
| Author: | CARS [ Wed Feb 13, 2008 11:59 am ] |
I used a POR kit last year on a tank and they just had me twirl it around for about 20 minutes, pour out the excess, and twirl again. If you have too much sealer in the tank, I don't see how just blowing it around will help. It is just a coating, once everything is covered I would get the rest out. |
| Author: | 66aCUDA [ Thu Feb 14, 2008 8:27 am ] |
Not to argue with Chris, but I would do it according to the directions. I think your trim compressor will work fine. My 02 Frank |
| Author: | CARS [ Fri Feb 15, 2008 10:47 am ] |
I frequent Eastwood's forum so I did some checking. http://forum.eastwoodco.com/showthread.php?t=7503 http://forum.eastwoodco.com/showthread. ... ank+sealer This should give you plenty of info to do the job right. |
| Author: | Bruce Johnson [ Sat Feb 16, 2008 1:54 pm ] |
aircraft spruce and specialty sells a kit for sloshing, normaly for riveted wing tanks pricey but good and reliable for 2-3 car tanks |
