It is currently Sun Nov 22, 2026 3:58 am
 Post subject: Gas tank resealing
PostPosted: Wed Feb 13, 2008 11:03 am
I got my kit from Eastwood to reseal the gas tank last night. The instructions say to use compressed air at 1-5 psi to keep the sealer from pooling as it dries. I am supposed to seal the sending unit opening, insert the compressed air from the filler opening and keep it from getting too close to any one surface so it doesn't create a thin spot.
I have an air compresser I use for trim work around the house and a nozzle to blow air. Will this work? Has anyone ever done this?
God took you away, then brought you back to me.
PostPosted: Wed Feb 13, 2008 11:59 am
I used a POR kit last year on a tank and they just had me twirl it around for about 20 minutes, pour out the excess, and twirl again.
If you have too much sealer in the tank, I don't see how just blowing it around will help. It is just a coating, once everything is covered I would get the rest out.
Chris'
Autobody
Restoration
Service
PostPosted: Thu Feb 14, 2008 8:27 am
Not to argue with Chris, but I would do it according to the directions. I think your trim compressor will work fine.
My 02
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Fri Feb 15, 2008 10:47 am
I frequent Eastwood's forum so I did some checking. http://forum.eastwoodco.com/showthread.php?t=7503
http://forum.eastwoodco.com/showthread. ... ank+sealer
This should give you plenty of info to do the job right.
Chris'
Autobody
Restoration
Service
PostPosted: Sat Feb 16, 2008 1:54 pm
aircraft spruce and specialty sells a kit for sloshing, normaly for riveted wing tanks pricey but good and reliable for 2-3 car tanks
78b4ramSnortbed/6
Users browsing this forum: Bing [Bot], Google [Bot] and 23 guests
