Changing rocker ratio
https://slantsix.org/forum/viewtopic.php?t=27242
Page 1 of 1
Author:  heckshemi [ Sun Feb 17, 2008 5:07 pm ]
Post subject:  Changing rocker ratio
I gained some experience cutting and welding rocker arms on my hemi head project so I thought I would try it on some stock slant rockers.
I checked a few and they were around 1.47 to 1. By cutting 1/16" gives a 1.55 ratio, cutting 1/8" gives 1.65 ratio. Since they are steel they're easy to weld. You can also compensate for pushrod length when welding. Cheap way to increase rocker ratio.
Author:  sandy in BC [ Sun Feb 17, 2008 5:40 pm ]
Will the pushrods clear the head?
Author:  heckshemi [ Mon Feb 18, 2008 12:36 pm ]
They should clear the head, I only cut 1/16" on this rocker. If you go 1/8" there may be some grinding needed.
Author:  Dart270 [ Mon Feb 18, 2008 3:10 pm ]
You da man, Mr. Heck.
Author:  daniel_depetro [ Thu Nov 20, 2008 4:40 pm ]
Very interesting...
Author:  steponmebbbboom [ Thu Nov 20, 2008 5:15 pm ]
that adjuster is an interference-fit, and you are cutting and welding that end of the rocker, has this disturbed the clamping force on the adjuster threads?
