Rear 10" drum backing plate question
https://slantsix.org/forum/viewtopic.php?t=27287
Author:  bmimken [ Tue Feb 19, 2008 12:52 pm ]
Post subject:  Rear 10" drum backing plate question
I am converting my a-body 8.75 rearend from small bolt pattern to big bolt pattern by replacing my axles with new ones. I have the factory 10" rear drum brakes on it currently. My question is: Will the backing plates on it now work with BBP 10" drums? I am aware there is a difference in width between the SBP and BBP 10" drums. Would this difference necessitate a change in backing plates?
Thanks, Brian
Author:  Rob64GT [ Sat Feb 23, 2008 9:12 am ]
The short answer is yes. You will need different backing plates if you purchased Yukon axles or cut down c-body axles.
Author:  bmimken [ Sun Feb 24, 2008 6:56 am ]
Thanks, I got the Yukon axles, so I guess I am going to need different backing plates.
Brian
