| time/ing on 1985 Ramm 100 slant 6, 3 speed over drive? https://slantsix.org/forum/viewtopic.php?t=27308 |
| Author: | Evilsizer [ Wed Feb 20, 2008 12:45 pm ] |
well my duster with the /6 died at idle too. turned out to be a dry rotted fuel line, then just needed the mixure on the carb redone after that. though my duster is a 76. have you checked out the fuel lines though? |
| Author: | USAJon [ Wed Feb 20, 2008 2:18 pm ] |
no. did it leak? I think it may be a dead idle control valve...it looks eletric and it does not move cold or warmed up... any idea of the time/ing set...I put a light on it and the pully mark (which i marked with a soapstone) wasnt even on the degree plate it was futher down to the left looking down from the front of the motor, and I move the distributor to get it in the middle of the degree palte...it jumped around quite a bit...why would it do that? motor has 156K super clead when i replaced the valve cover gasket. 1 owner truck when i bought tit. |
| Author: | USAJon [ Wed Feb 20, 2008 2:57 pm ] |
youtube video...there's a lot of under the hood noise..air pump has pin holes for about 1 inch..motor itself is quiet..motor does jump around @ idle...probally to low too. http://www.youtube.com/watch?v=4VVCGqp1npE |
| Author: | Evilsizer [ Wed Feb 20, 2008 3:02 pm ] |
no i didnt notice any leaks at all from it. i think it was lack of pressure... i dont know about the timing, i havent had to do that is so long. since the duster any way, i havent driven it in 5-6years. plus im having to learn/relearn the car stuff. |
| Author: | SlantSixDan [ Wed Feb 20, 2008 3:19 pm ] |
Welcome on the board. Correct ignition timing depends on the part number of your truck's spark control computer, as follows: 4289601: 16 deg 4289603: 12 deg 4289613: 12 deg 4289615: 16 deg 4289617: 12 deg 4289621: 12 deg 4289637: 8 deg The spark control computer itself is a prime suspect with problems like this. It should be eliminated if your local regulations permit it. Start by reading this thread. |
| Author: | Aggressive Ted [ Wed Feb 20, 2008 8:19 pm ] |
That is your voltage regulator......not much magic from it...... |
| Author: | USAJon [ Wed Feb 20, 2008 8:42 pm ] |
Ha! well what/where is the spark control computer . whats it look like ? |
| Author: | SlantSixDan [ Wed Feb 20, 2008 11:02 pm ] |
I am pretty sure it's tucked in the left inner fender behind the battery. |
| Author: | USAJon [ Thu Feb 21, 2008 9:54 am ] |
yep...just where u said it was... 4289603 Im thinking it's the canaster's charcoal...I put 2 bottels on 2 fill ups of rubbing achoal 90%. i always do this on old vehicles that sit. Im thinking the charcoal has fe'd the carb..read a post while searching here on that happening...we c.. |
| Author: | USAJon [ Sat Mar 01, 2008 9:05 pm ] |
put rebuild carb on runs great ! |
