| Is 78 Aspen 2dr good donor for 68 dart 4dr brake conversion. https://slantsix.org/forum/viewtopic.php?t=27335 |
| Author: | 4.20 [ Thu Feb 21, 2008 11:48 pm ] |
| Post subject: | Is 78 Aspen 2dr good donor for 68 dart 4dr brake conversion. |
Hi All, New to the mopar family and need some techical guidance. I already have a 68 4dr /6 dart with the 9"drums. Been interested in upgrading my brakes and now have an opportunity to get a 78 aspen /6 2dr with discs. What I would like to know is if the this would be a suitable donor or am I limited to pre 76 A-bodies for my conversion. Also, will this be a super six car? Thanks for the help, Cheers |
| Author: | dakight [ Fri Feb 22, 2008 4:11 am ] |
The spindles, hubs, rotors and calipers can be used but you will need to find 73+ A-body upper control arms to complete the swap. The spindles are not identical but concensus is that they work fine. I don't know about the master cylinder but my guess is that it will be suitable as will the proportioning valve. Others may want to shed more light on the subject. |
| Author: | Sam Powell [ Fri Feb 22, 2008 5:47 am ] |
This car has a master cylinder from a Volare. It works fine. You will need to either make or buy an adapter do bolt it up. I simply cut the back off of the old master cylinder, smoothed it up with a file, and taped it for the studs required to mount the newer MC. Sam |
