| Towing with a Slant Six D150 truck https://slantsix.org/forum/viewtopic.php?t=27342 |
| Author: | tlrol [ Fri Feb 22, 2008 8:02 am ] |
| Post subject: | Towing with a Slant Six D150 truck |
Hey Slant Fans, Any idea what a practical limit is on towing with a 1982 Slant Six Dodge D150 truck. For what its worth the owners manual says 2000 pounds--that is specifically the limit for a Slant Six with an A 833 OD transmission (what I have). Given that the rear end is a 3.2 that seems reasonable enough, also the stock 1 bbl carburetor wouldn't help either. But...what fun is there in following the manufacturers recommendation. So, given that this truck has power disc brakes and a shiny new Weber 2 bbl (It got Super Six'd) in it do you folks think I could perhaps tow up to 5000 pounds IF I swapped out the rear end for a 4.1 ratio? I believe that the A833 transmission is up to towing under the 5K mark but the 3.2 ratio is really hopeless for that. I did some digging on modern rigs and it seems that 6 cylinders come in at 4000 or so pounds of towing. It looks like torque multiplication is the key on the rear, I just want to make certain the A833 4 speed won't die doing it. Also, any other tips? Does shaving the head make that big of a difference on a Slant engine? I know the Weber woke it up, jetting was a pain (much Voodoo involved in getting it dialed in) so I imagine shaving the head would do wonders as well. Anyway, this is a full sized D150, the Miser model with a Slant in it. I know the frame and brakes are good for 5000 with a V-8 under the hood (so says Dodge)--this is with an NP tranny though. I know the right answer for towing is to buy a monster diesel with a 16,000 tow capacity, but hey, this was Grandfathers one and only new truck so I thought I would give it some love and use it and the same time. FYI, Slants are way tough--this thing sat under a pine tree on a farm for 15 years, never moved at all. I dug it out, cleaned out the pine trees that were growing in the back, put a new battery in it, poured gas down the carburetor and it cranked right up. I drove the thing 400 miles to my home afterwards--crazy but it did fine. Manual disc brakes--that was interesting... Thanks all and happy Slanting |
| Author: | Rob Simmons [ Fri Feb 22, 2008 8:21 am ] |
Welcome to the Forum! It sounds like a nice truck you have. We'd love to see some photos in the Slixer's Gallery section. You'll surely get some responses on towing soon. Opinions will likely vary widely I won't offer an opinion as I tend to go over the manufacturers recommendations on things... Shaving/milling the head on a slant 6 really does do wonders as these engines came with very low compression originally. Sometimes in the very low 8._ :1 ratio. Milling is one of the most recommended upgrades for increase performance (after the super six and better exhaust Do some poking around in the various sections and you'll find TONS of good information! You may very likely even find a thread or two regarding towing capacities etc using the Search function. Welcome aboard! |
| Author: | volaredon [ Fri Feb 22, 2008 8:31 am ] |
sounds like the truck I'd like to find! In answer to your question I had a 79 D 100 shortbed 3 on the tree manual steering and brakes an I remember towing 4500# with it no problem. Another buddy had an 87 D 150 slant 6, 904 that he bought new and towed his 66 Coronet big block car to Union Grove Wis (Great Lakes Raceway) several times a summer; when he first started out it was slow getting up to speed but the truck handled it fine. Ask CharrlieS; he's got a couple of 80s, /6 Dodge trucks and its been a while but I seem to remember a couple of towing stories with his trucks. |
| Author: | Joshie225 [ Fri Feb 22, 2008 9:57 am ] |
With 4.10s out back and attention to the brakes you should be able to tow 3000 lbs easily. I would use Redline MT-90 in the transmission. I know it's about $9 a quart and you need 4 quarts, but it really helps with the shifting and will last nearly forever provided the transmission doesn't leak. In 1998 I loaded my '74 D100 Club Cab slightly over it's GVWR and then put a '71 Dart on a tow dolly behind it and drove from Mountain View, California to Portland, Oregon. My slant powered truck was equipped with a 727 and 3.55 gears. It was slow, but it did the job. If I had to do it over again I'd swap in power brakes and Raybestos Super Stop pads. |
| Author: | mopar_nocar [ Fri Feb 22, 2008 10:04 am ] |
You have my exact truck. (well mines a regular super six.) I tow my boat all the time. A 3.91 ratio rear will be going in this summer. Once I do that; this will be my only towing rig. Its got upteen jillion miles on it; once it starts to get weak I'll do some stuff to it and it'll tow like the V8 (sorta) that is in your owners manual. I had a set of 4.10s to put in; but they went into a race car instead. Oh well. sb |
| Author: | sandy in BC [ Fri Feb 22, 2008 10:16 am ] |
I would tow no more than 5000lbs with a 1/2 ton. Its about brakes and suspension. Its always fun to put a S10 brake shoe next to the 13x3.25 shoes from my Suburban...... |
| Author: | tlrol [ Fri Feb 22, 2008 1:19 pm ] |
| Post subject: | Thanks... |
Wow--talk about service, tons of answers in no time. Sounds like if I drop an Auburn rear end in it in the 3.9 to 4.1 range I should be good to go as far as towing goes. I was checking out Gear Vendors overdrive units, they look really nice (expensive though). I am not a fan of the howling noise you get from high numerical ratios at 65 mph. My Land Rover has 4.51 gears in it, it will climb a tree but at 65 mph I wear ear plugs! I will have to see if I need a Gearvendors O/D with a 4.1 in the rear end. Thanks! FYI, this D150 has 37,000 original miles on it, a new truck almost. Aside from the paint, weather stripping, and anything that the mice ate it is like new... Runs great though. I will have to snap some pictures with some new paint on it. Amazing how 15 years sitting in a field didn't bother some things on it. Other things didn't fair so well--like brake lines being rusted tight with the wheel cylinders, etc. Another FYI--all new stainless pre-bent brake lines cost $210 dollars (with shipping)... a good deal compared to fighting with rusted tinned steel lines... Thanks for all the posts--this is a great place for info on the Slants. I did the Super Six and Lean Burn delete based on info from here. If anyone every does a Weber 32/36 swap I have good jetting info on those (always check the float first, factories DON'T follow their own specifications!). |
| Author: | Slant Cecil [ Fri Feb 22, 2008 2:22 pm ] |
I tow with my '84 D100, 225, 833OD, mileage is 140,000. I made several changes to improve towing, 2.25" exh, 2bbl BBD, deleted the ESC with regular electronic set at 30* total. Each change only made very slight improvements. Getting it rolling was a challenge, especially on an incline. Once I had it moving, was OK. My last change was a 8.75" 3.91SG rear for the original 8.25" 3.21open. This made a HUGE difference. I sold and delivered a 4000lb Charger a few years back, I thought I'd lose the clutch before I got it moving with the 3.21 gear. Now with the 3.91s, it gets moving with no effort when towing an A body. My 5400lb JD tractor only needs a bit of persuading. Here's the truck, my old Charger and the day I sold it. ![]() ![]()
| Author: | Rob Simmons [ Fri Feb 22, 2008 3:54 pm ] |
Hey Cecil, I like the new tire/wheel combo. They really make a difference in the truck's looks. I sure do miss having a pick 'em up truck! That will be one of my first purchases when I get back to the states. |
| Author: | Joshie225 [ Fri Feb 22, 2008 4:01 pm ] |
| Post subject: | Re: Thanks... |
Why the GV overdrive? Your truck already has overdrive. Do you want to split gears? I ran Richmond 4.10 gears in an 8 3/4 and they were pretty darn quiet. Factory gears are usually quieter. With the A833OD freeway cruising was effortless. 4.10s with the .73 OD equates to a 2.99 overall high gear. Quote: I was checking out Gear Vendors overdrive units, they look really nice (expensive though). I am not a fan of the howling noise you get from high numerical ratios at 65 mph.
| Author: | tlrol [ Fri Feb 22, 2008 7:02 pm ] |
| Post subject: | Gear vendor O/D |
You hit it right on the head Joshie--I wouldn't mind gear splitting on that A833. First gear is short, second is a sloooowwww run, and third is the working gear...it is really a 3 speed with overdrive. If I could buy a Gearvendor rig for $100 bucks I would jump on it. Sadly, they cost around $2500; ouch I say. It would be nice to have a few more gears in it. In any case, I will try the 4.1 ratio for a long time before I consider the GearVendor O/D. It would be fun to have though, clutchless shifts and all that... If I knew I was going down the path of a tricked out overdrive from GearVendors I would use a 4.56 in the back end, talk about having your cake and eating it too. I would have the same final drive ratio I have now and stump pulling low. Plus having an "8 speed" would be cool. Anyway, you are correct, it shouldn't be a problem with the 4.1--mostly trying to figure a way to sneak in that O/D unit by spinning a tale for my wife! |
| Author: | volaredon [ Fri Feb 22, 2008 8:52 pm ] |
Like Cecil (sorry I thought it was Charlie... had my Florida guys mixed up there) my truck had 3.91s in it with the 833OD. |
