| Double roller timing chain? https://slantsix.org/forum/viewtopic.php?t=27347 |
| Author: | pinkiedog64 [ Fri Feb 22, 2008 11:29 am ] |
| Post subject: | Double roller timing chain? |
I'm accumulating parts for my /6 build and am looking for a timing chain right now. Is a double roller necessary when building a hot /6? If so, where can you buy them? I haven't seen any other than the stock type chains. Also, I assume a double roller fits just fine under the stock timing cover and fits on the same as a stock unit? Thanks |
| Author: | Greg Ondayko [ Fri Feb 22, 2008 12:56 pm ] |
Double roller will be more durable and if you run a big cam with Higher valve spring pressures probably a wise investment. Here are some options and they fit under a stock cover. http://www.slantsix.org/forum/viewtopic.php?t=11426 http://www.slantsix.org/forum/viewtopic.php?t=18147 http://www.slantsix.org/forum/viewtopic.php?t=26369 Hope this helps, Greg |
