It is currently Fri May 15, 2026 4:12 pm
 Post subject: cam selection
PostPosted: Sun Oct 07, 2001 2:15 pm
Looking for suggestions for a cam for an 85 Dodge Van. I have a competition cams solid lifter camshaft (Grind # 264S-10) that makes less power than the stock one... Looking for something with a little more power. Any suggestions would be appreciated.
brentmcl@home.com
 Post subject: Re: cam selection
PostPosted: Sun Oct 07, 2001 2:50 pm
: Looking for suggestions for a cam for an 85
: Dodge Van. I have a competition cams solid
: lifter camshaft (Grind # 264S-10) that makes
: less power than the stock one... Looking for
: something with a little more power. Any
: suggestions would be appreciated.
go to racesearch.com and check out the isky grinds. their 264/228*/".448 worked real well for me. they also deal with reed cams, reed will do custom grinds if desired.
beardliz@msn.com
