| starter pinon and flywheel teeth https://slantsix.org/forum/viewtopic.php?t=2742 |
| Author: | derek [ Mon Oct 08, 2001 10:18 am ] |
| Post subject: | starter pinon and flywheel teeth |
What are the tooth counts for slant 6 starter pinons and flywheel ring gears? I want to know, because I'm looking for an easy swap / fix for my straight "L" six (either a 236 or 251). derekacomb@hotmail.com |
| Author: | Doctor Dodge (Doug Dutra) [ Tue Oct 09, 2001 7:59 pm ] |
| Post subject: | Re: starter pinon and flywheel teeth |
: What are the tooth counts for slant 6 starter : pinons and flywheel ring gears? I want to : know, because I'm looking for an easy swap / : fix for my straight "L" six : (either a 236 or 251). All gear reduction Mopar starters have 10 teeth. The SL6 flywheel for the 10" clutch (and 9 1/4) has 122 teeth. There is no way a SL6 Bellhousing is going to bolt to your flathead L six, the starter is up to high. I think a V8 bell with an adaptor plate works. DD |
