| Which ATF for A904? https://slantsix.org/forum/viewtopic.php?t=2743 |
| Author: | dobie [ Mon Oct 08, 2001 3:51 pm ] |
| Post subject: | Which ATF for A904? |
Which transmission fluid should I use? My '64 904 just got back from a rebuild and I've almost got her reinstalled in my daily driver /6 '64 Valiant. The book calls for Type A (still available), the instructions with the transmission say Dexron II for all Chrysler transmissions, and Dexron III was all I saw at the two parts stores I checked. dobie79423@yahoo.com |
| Author: | Fopar [ Mon Oct 08, 2001 8:38 pm ] |
| Post subject: | Re: Which ATF for A904? |
: Which transmission fluid should I use? My '64 : 904 just got back from a rebuild and I've : almost got her reinstalled in my daily : driver /6 '64 Valiant. The book calls for : Type A (still available), the instructions : with the transmission say Dexron II for all : Chrysler transmissions, and Dexron III was : all I saw at the two parts stores I checked. I have used only type F in mine since I rebuilt it 4 years ago. The Dextron will not have as high a co-efficient of friction as the type F and you will get a smoother shift out of it, but using type F you will get a little bit more of a snap out of the shifts. the best part is if you don't like the way either one performs just change the fluid. dbjerklund@hotmail.com |
| Author: | will [ Tue Oct 09, 2001 12:08 am ] |
Type F is the way to go Will Quote:
: Which transmission fluid should I use? My '64 : 904 just got back from a rebuild and I've : almost got her reinstalled in my daily : driver /6 '64 Valiant. The book calls for : Type A (still available), the instructions : with the transmission say Dexron II for all : Chrysler transmissions, and Dexron III was : all I saw at the two parts stores I checked. slantsix@netzero.net |
| Author: | Dart270 [ Tue Oct 09, 2001 9:25 am ] |
: I have used only type F in mine since I rebuilt : it : 4 years ago. The Dextron will not have as high : a co-efficient of friction as the type F and : you will get a smoother shift out of it, but : using type F you will get a little bit more : of a snap out of the shifts. the best part : is if you don't like the way either one : performs just change the fluid. You can use Dextron III from the parts stores, or Type F. Fopar is right about the trends. Lou madsenl@caltech.edu |
| Author: | Andy Zeiner [ Tue Oct 09, 2001 3:55 pm ] |
: You can use Dextron III from the parts stores, : or Type F. Fopar is right about the trends. : : Lou I used some B&M high performance stuff in my Diesel truck which gave me a nice firm shift. Its blue in color and seems thinner than the red stuff we all are used to. I dont know if it is any good in a Torque Flight. Anyone have any experience with this stuff?? MrSlant@pacbell.net |
| Author: | dschumers [ Tue Oct 09, 2001 6:13 pm ] |
: I used some B&M high performance stuff in my : Diesel truck which gave me a nice firm : shift. Its blue in color and seems thinner : than the red stuff we all are used to. I : dont know if it is any good in a Torque : Flight. Anyone have any experience with this : stuff?? Trick Shift is basically Type F fluid with blue dye instead of red. aschumers@aol.com |
