| Rocker Slippage https://slantsix.org/forum/viewtopic.php?t=2746 |
| Author: | Dan Kalcic [ Tue Oct 09, 2001 12:29 pm ] |
| Post subject: | Rocker Slippage |
Hello, I have a '63 slant 6 with a #5 rocker arm that slipped on its axis such that the arm disengaged from the valve and pushrod. I have never adjusted the valves. Is this disaster a result of loose valve adjustments? Any suggestions would be helpful before attempting to reposition the rocker arm. regards, Dan dkalcic@mail.arc.nasa.gov |
| Author: | Andy Zeiner [ Tue Oct 09, 2001 3:50 pm ] |
| Post subject: | Re: Rocker Slippage |
: Hello, : : I have a '63 slant 6 with a #5 rocker arm that : slipped on its axis such that the arm : disengaged from the valve and pushrod. I : have never adjusted the valves. Is this : disaster a result of loose valve : adjustments? Any suggestions would be : helpful before attempting to reposition the : rocker arm. : : regards, : : Dan The old Dodge adjustable rockers do eventually wear out and wont stay in adjustment. I would try to adjust the valves at .010 intake/ .020 exhaust (for a stock cam) while the engine is hot and running. If the rocker goes out again you can get a rebuilt rocker shaft assembly from Kanter Assoc in New Jersey for about $40 or you can get the ARP long adjusters and double nut them and they will never slip. Hope this helps MrSlant@pacbell.net |
| Author: | Doc [ Tue Oct 09, 2001 4:06 pm ] |
: Hello, : : I have a '63 slant 6 with a #5 rocker arm that : slipped on its axis such that the arm : disengaged from the valve and pushrod. I : have never adjusted the valves. Is this : disaster a result of loose valve : adjustments? Any suggestions would be : helpful before attempting to reposition the : rocker arm. : regards, : Dan Loose valve adjustment, a bent pushrod, a sticking valve guide or a poorly aligned rocker to valve stem tip could cause the racker to "jump-off". "Roll" the pushrod to make sure it is not bent, check the rocker arm side clearance and adjust as needed. (rocker shaft retainer washers) Once everything is back together, re-torque the head and adjust the lash. DD |
