It is currently Fri May 29, 2026 11:08 pm
PostPosted: Tue Feb 26, 2008 2:09 pm
I have a 73 duster and a 74 dart. I am going to be installing stock rally wheels (small bolt on the duster, large bolt on the dart). I want to order the chrome lugs for the wheels, but am unsure what to order, can anyone tell me what they take?
PostPosted: Tue Feb 26, 2008 2:18 pm
my lugs are 7/16-20
this is on a 72 valiant wit a 7-1/4, should be the same, hope that helps
PostPosted: Tue Feb 26, 2008 3:24 pm
Car Model: '23 T-bucket
Redfive.....I don't think you'll have a problem with this, but physically check anyway. You may have left-hand threads on the left side of that Duster. Being as it's a small-bolt, it might, but it's also a '73, sooooo.
Roger
PostPosted: Tue Feb 26, 2008 3:26 pm
if its got the original rear in it no, they stopped that nonsence in 68 i believe
'72 Valiant DD for over a decade-225-Disc brakes, big T-bars, big Sway bars f/r, carter bbd/super six, GM HEI, 2- 12" subs in trunk, 1000w amp...
'77 cherokee cheif widetrack-360-33x12.5 tires-no lift. keeps driveway dry-project/backup DD/mudder
PostPosted: Tue Feb 26, 2008 5:15 pm
Dank, A-bodies used left hand thread through 72 and changed over in mid 73
