| Shock mounts revisited https://slantsix.org/forum/viewtopic.php?t=27469 |
| Author: | NewSlanter [ Tue Feb 26, 2008 3:06 pm ] |
| Post subject: | Shock mounts revisited |
Ok, so I found a fellow locally who has a pair of shock mount studs that are the right size for my application. I'm going to pick them up tonight. The plan is to cut off the existing studs, drill a hole in the right spot and bolt them in. Is this the right way to do it or do I need to have the studs welded in place? Welding is something I can't do, so if I can get away with simply bolting them in I'm golden. Thanks in advance, Nat |
| Author: | sandy in BC [ Tue Feb 26, 2008 3:35 pm ] |
Bolt. It will be easier next time. |
| Author: | NewSlanter [ Tue Feb 26, 2008 6:15 pm ] |
Outstanding! Thank you sir. |
| Author: | slantzilla [ Wed Feb 27, 2008 6:47 am ] |
If you can drill the hole, by all means bolt them in. |
| Author: | NewSlanter [ Wed Feb 27, 2008 7:41 am ] |
Quote: If you can drill the hole, by all means bolt them in.
A drill I can work. A welder..... Let's just say I've welded once and I managed to flash myself twice. Nat |
| Author: | sandy in BC [ Wed Feb 27, 2008 8:11 am ] |
Quote: I managed to flash myself twice
Best to keep your pants on while weldink......
| Author: | NewSlanter [ Wed Feb 27, 2008 8:17 am ] |
Where's the fun in that? |
| Author: | slantzilla [ Wed Feb 27, 2008 9:07 am ] |
Quote: Quote: I managed to flash myself twice
Best to keep your pants on while weldink...... |
| Author: | vynn3 [ Wed Feb 27, 2008 11:10 am ] |
