| new turbo setup https://slantsix.org/forum/viewtopic.php?t=2747 |
| Author: | andrew wagner [ Tue Oct 09, 2001 4:05 pm ] |
| Post subject: | new turbo setup |
Hey guys its been a while but I have been busy on a new turbo setup. I went to a big .63 a/r to3 turbo and a 600 dp holley, the same intercoolers, a hks blowoff valve, sub frame connectors, mandral bent 3 inch exhaust, and a costom header as soon as I change one pipe around. The car is running but there is some tuning to do. Hopefully it will be in the 14s when its ready.(with stock internals) andrew wagner |
| Author: | dschumers [ Tue Oct 09, 2001 4:29 pm ] |
| Post subject: | Re: new turbo setup |
: Hey guys its been a while but I have been busy : on a new turbo setup. I went to a big .63 : a/r to3 turbo and a 600 dp holley, the same : intercoolers, a hks blowoff valve, sub frame : connectors, mandral bent 3 inch exhaust, and : a costom header as soon as I change one pipe : around. The car is running but there is some : tuning to do. Hopefully it will be in the : 14s when its ready.(with stock internals) Where did you get your header Andrew? Good luck getting into the 14's!!!!!!!! Dennis : andrew wagner aschumers@aol.com |
| Author: | andrew wagner [ Tue Oct 09, 2001 6:24 pm ] |
I made it myself. andrew wagner Quote:
: Where did you get your header Andrew? Good luck : getting into the 14's!!!!!!!! Dennis |
| Author: | motorhedfred [ Fri Dec 28, 2001 9:12 am ] |
Hey Andrew, how some pics of your home made header ? motorhedfred Quote:
: : Hey guys its been a while but I have been busy : on a new turbo setup. I went to a big .63 : a/r to3 turbo and a 600 dp holley, the same : intercoolers, a hks blowoff valve, sub frame : connectors, mandral bent 3 inch exhaust, and : a costom header as soon as I change one pipe : around. The car is running but there is some : tuning to do. Hopefully it will be in the : 14s when its ready.(with stock internals) : : andrew wagner motorhedfred@yahoo.com |
