| 74 dart exhaust pipe https://slantsix.org/forum/viewtopic.php?t=27487 |
| Author: | Bobby Rock [ Wed Feb 27, 2008 9:39 am ] |
| Post subject: | 74 dart exhaust pipe |
Hi all, Today I was going to replace the gasket where the exhaust pipe meets the manifold. When I removed the nut and bolt, the flange was completely broken off from the pipe. I am new to this, and I need some help and direction from the experts here. Does the pipe separate from the muffler? I couldn't see just by looking at it. If it does, how? And is the exhaust pipe something I can get at napa or similar auto parts stores? Any help/advice would be greatly appreciated! Thanks. |
| Author: | SlantSixDan [ Wed Feb 27, 2008 9:59 am ] |
Replacement headpipes used to be available pre-bent from parts stores, but they've long been discontinued. A reputable independent exhaust shop (not a chain place like Midas, Meineke or Speedy) will be able to make and install a new headpipe. You may want to take this opportunity to install a 2¼" headpipe as the factory did starting a few years after your car was made, rather than your original 1¾" headpipe — this will improve your driveability, performance, and fuel economy. Unless your muffler and tailpipe are relatively new, it's likely they'll need replacing as well. |
