| Is a 750cfm holley to much for a /6 https://slantsix.org/forum/viewtopic.php?t=2754 |
| Author: | Bob [ Tue Oct 09, 2001 11:09 pm ] |
| Post subject: | Is a 750cfm holley to much for a /6 |
Is a 750 cfm holley to much for a /6? Will i have any problems idle,stop and go daily driving.Am I crazy to put this on my daily driver. vicious1@hotmail.com |
| Author: | Dart270 [ Wed Oct 10, 2001 8:22 am ] |
| Post subject: | Re: Is a 750cfm holley to much for a /6 |
: Is a 750 cfm holley to much for a /6? Will i : have any problems idle,stop and go daily : driving.Am I crazy to put this on my daily : driver. Yep, it's way too much. If you manage to make 350 HP, then maybe you can run it. Even a 600 is a bit on the big side. I have found the Edelbrock 500 4bbl works well on medium built motors, and otherwise you should go smaller than that. Lou |
| Author: | andrew wagner [ Wed Oct 10, 2001 4:51 pm ] |
I have a 600 dp but I run a turbo down thru it. it is okay if I do not get into th seconderies to soon. andrew wagner Quote:
: Yep, it's way too much. If you manage to make : 350 HP, then maybe you can run it. Even a : 600 is a bit on the big side. I have found : the Edelbrock 500 4bbl works well on medium : built motors, and otherwise you should go : smaller than that. : : Lou |
